*attributeupdateintarrayelementmark
Updates one element of an attribute of type int array.
*attributeupdateintarrayelementmark entity type mark identifier solver status behavior index value
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
mark
The number of the mark.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
index
Index into the array, starting at zero.
value
The integer value to be placed into the array.
Examples
*attributeupdateintarrayelementmark(loadcols, 1, 5000, 1, 2, 0, 0, 4)
