*loadsupdate
Updates the magnitude, direction, and coordinate system of selected loads.
*loadsupdate mark config type updatevector component [1-6] updatemag magnitude update_system system_id transform_flag
HyperMesh Tcl Modify Command
- markmask
 - ID of the mark containing the loads to update.
 - config
 - The configuration of the load:
 - type
 - The type assigned to the load (as defined on the Load Types panel).
 - updatevector
 - A variable that controls if the direction of the load should be updated.
 - component[1-6]
 - Components of the load being applied. When applying a force, the active components are 1, 2, and 3, which represent a force x, y, and z-axis, respectively.
 - updatemag
 - An integer variable that controls if the magnitude is updated.
 - magnitude
 - The new value of magnitude of the load.
 - update_system
 - A variable that controls if the system is updated.
 - system_id
 - The ID of the local system.
 - transform_flag
 - A simple integer variable that controls if the load is created in the local system.
To update a force of 10 N along the y axis to a force of 20 N along the y axis:
*createmark(loads,1) 4
*loadsupdate(1,1,1,0,0,1,0,0,0,0,1,20,0,0,1)
      *loadsupdate() is the update command for all loads.
None.
