*defaultmeshelems
Meshes a selection of elements using saved or default parameters and various options.
*defaultmeshelems mark_id elem_size elem_type elem_type_2 comp_mode size_control skew_control edge_mesh_type min_size max_size max_deviation max_angle previous_settings vertex_angle
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the elements to mesh. Valid values are 1 and 2.
 - elem_size
 - The default element size used to calculate element densities along edges (when necessary).
 - elem_type
 - Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
- 0 - trias
 - 1 - quads
 - 2 - mixed
 - 3 - right trias
 - 4 - quads only
 - elem_type_2
 - Flag indicating the elements generated for free meshing algorithms. Valid values are:
- 0 - trias
 - 1 - quads
 - 2 - mixed
 - 3 - right trias
 - 4 - quads only
 - comp_mode
 - Parameter specifying how entities are organized into components:
- 0 - Elements are created in the current component. Boundaries between components are not maintained when remeshing.
 - 1 - Elements are created in the same components as the source elements. Boundaries between components are maintained when remeshing.
 - size_control
 - Flag indicating whether to create uniformly sized elements. Valid values are:
- 0 - Do not create uniformly sized elements.
 - 1 - Create uniformly sized elements.
 - skew_control
 - Flag indicating whether to create optimally shaped elements when using mapping
- 0 - Do not create optimally shaped elements.
 - 1 - Create optimally shaped elements.
 - edge_mesh_type
 - Determines the algorithm for edge meshing:
- 1 - Standard edge meshing.
 - 2 - Chordal deviation edge meshing.
 - 11 - Standard edge meshing with flow "align" control.
 - 12 - Chordal deviation edge meshing with flow "align" control.
 - 14 - Standard edge meshing with flow "align" and "size" control.
 - min_size
 - Minimum edge size for chordal deviation edge meshing. Ignored, if edge_mesh_type is not set to 2 or 12.
 - max_size
 - Maximum edge size for chordal deviation edge meshing. Ignored, if edge_mesh_type is not set to 2 or 12.
 - max_deviation
 - Maximum deviation for chordal deviation edge meshing. Ignored, if edge_mesh_type is not set to 2 or 12.
 - max_angle
 - Maximum angle value (in degrees) between edges for chordal deviation edge meshing. Ignored, if edge_mesh_type is not set to 2 or 12.
 - previous_settings
 - Flag indicating whether to break, keep or redo connectivity between neighboring
            surfaces. Valid values are:
- 0 - Keep previous settings and do not break connectivity between neighboring surfaces.
 - 1 - Break connectivity between neighboring surfaces.
 - 2 - Keep connectivity between neighboring surfaces.
 - 3 - Redo connectivity between neighboring surfaces by expanding surface selection by one layer of adjacent surfaces.
 - vertex_angle
 - When the vertex between two edges exceeds this value, a new node is created to form a vertex. Thus, using high values results in fewer nodes on curved edges, and therefore less-accurate edge approximation. A standard value is 30.
Examples
*setoption element_order=1
*setoption feature_angle=20
*setusefeatures 3
*createmark elems 1 all
*defaultmeshelems 1 4.5 2 2 1 1 1 14 0 0 0 0 2 25Errors
   # Handle error
