*convertthickness
Converts the thickness of the specified entities to the target solver.
*convertthickness entity_type mark_id source_solver_id target_solver_id
HyperMesh Tcl Modify Command
Currently this is supported only for Nastran to Abaqus conversion. It converts the element thickness to nodal thickness and puts the converted nodes on mark 1.
- entity_type
 - Entity type to convert. Currently only elements are supported.
 - mark_id
 - The ID of the mark containing the entities to update. Valid values are 1 and 2.
 - source_solver_id
 - The ID of the source solver for the specified entities. This can be queried using hm_getsolver.
 - target_solver_id
 - The ID of the target solver for the specified entities. This can be queried using hm_getsolver.
Examples
*createmark elems 1 1-100
*convertthickness elements 1 1 2Errors
   # Handle error
}Version History
11.0
