*createandadjustmass
Adjusts mass for a selection of source components by creating solvermasses on the target components.
*createandadjustmass entitysource=<value> marksource=<value> targetmass=<value> targetcogx=<value> targetcogy=<value> targetcogz=<value> ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
addnumericalmass=<value>
0 - Do not add numerical mass (default)
1 - Add numerical mass coming from time step on the source entities
The source entity type. Must be set to comps. This is mandatory.
entitytarget=<value>
The target entity type. Valid values are comps and nodes. If not specified, the source entities are updated.
marksource=<value>
The ID of the mark of source entities. Valid values are 1 and 2. This is mandatory.
marktarget=<value>
The ID of the mark of target entities. Valid values are 1 and 2.
targetcogx=<value>
The target x-COG. This is mandatory.
targetcogy=<value>
The target y-COG. This is mandatory.
targetcogz=<value>
The target z-COG. This is mandatory.
targetmass=<value>
The target mass value. This is mandatory.
tolerance=<value>
The percentage tolerance on mass to be adjusted.
usestructuralmass=<value>
0 - Use engineering mass (default)
1 - Use structural mass
Examples
To adjust mass on all the components with specific target mass and COG values:
*createmark comps 1 all
*createandadjustmass marksource=1 entitysource=comps targetmass=0.0245 targetcogx=-277.65 targetcogy=-0.49188 targetcogy=-0.49188 tolerance=10.0 usestructuralmass=1 addnumericalmass=1
   # Handle error
Version History
2021
