*morphconstraintupdatesurf
Creates a surface type morphconstraint for the selected nodes with the option of having those nodes either move along the surface or be bounded by it.
*morphconstraintupdatesurf ntype nmark type mcon vec surf dist ivec color
HyperMesh Tcl Modify Command
This command updates a surface type morphconstraint for the selected nodes with the option of having those nodes either move along the surface or be bounded by it.
- ntype
 - Must be set to nodes.
 - nmark
 - The ID of the mark for the constrained nodes. Valid values are 1 and 2.
 - type
 - 0 - Moves along the surface
 - mcon
 - The ID of the morph constraint to update.
 - vec
 - The ID of the vector created using *createvector. Must be set to 1.
 - surface
 - The ID of the surface.
 - dist
 - The minimum distance from the bounding surface.
 - ivec
 - 0 - The surface normal is used for distance and projection. The nodes will be moved normally to the surface when constraining them or measuring the distance the nodes are away from the surface.
 - color
 - The color of the constraint. Valid values are 1-64.
To update a morphconstraint for nodes to move along a surface and projected normally to the surface:
*createmark nodes 1 1 2 3 4 5
*createvector 1 1.0 0.0 0.0
*morphconstraintupdatesurf nodes 1 0 12 1 12 0.0 0 32
   # Handle error
