*morphloaddata
Loads handle and/or shape data from a file.
*morphloaddata morphdatafile mode hand shape
HyperMesh Tcl Modify Command
- morphdatafile
 - name of data file written using *morphsavedata().
 - mode
 - 0 - Append to model.
 - hand
 - 0 - Ignore handles in file.
 - shape
 - 0 - Ignore shapes in file.
Overwriting handles will force the deletion of all handles in the global domain.
Overwriting shapes will delete all shapes in the model.
Appending for either handles or shapes will cause any existing handle shape with that name to be renamed. The handles and shapes read in will retain their names.
Appending for handles will create a new global domain.
*morphloaddata ("global.dat",1,1,1)
None.
