*surfacesplinefrommesh
Creates geometry on selected 2D mesh elements. Uses selected plot elements to create edges between surfaces.
*surfacesplinefrommesh shellelemmarkmask edgeelemmarkmask tol
HyperMesh Tcl Modify Command
- shellelemmarkmask
 - Selection markmask for 2D mesh elements that are used to create surfaces.
 - edgeelemmarkmask
 - Selection markmask for plot 1D elements that are used to create boundaries between created surfaces.
 - tol
 - Maximal deviation of mesh points from created surfaces at boundaries. If the value is set to 0 or is negative, deviation is calculated internally based on the average size of mesh elements.
To create geometry that fits set of 2D elements selected by markmask 1 and use 1D elements selected by markmask 2 to create boundaries between surfaces. Use automatically calculated tolerance for created boundaries.
*surfacesplinefrommesh(1, 2, 0)
      Selection markmask for elements are created by *createmark command. The type of selected elements is being checked internally before processing. Therefore, the option for global selection (*createmark(elements,1) "displayed", for example) can also be used.
None.
