*boolean_merge_solids
*boolean_merge_solids entitymarkA entitymarkB opcode options
HyperMesh Tcl Modify Command
- entitymarkA
 - Markmask of solid entities in set A.
 - entitymarkB
 - Markmask of solid entities in set B.
 - opcode
 - Code of boolean operation to be performed.
 - options
 - Currently used to specify how to process internal shared boundaries in resulted solid or solids.
