*marksmoothsolids
Applies a simple smoothing algorithm to reposition the interior floating nodes in a mesh of solid elements, attempting to moderate variations in element size and quality.
*marksmoothsolids mark iterations
HyperMesh Tcl Modify Command
- mark
 - The mark of the solid elements.
 - iterations
 - The number of times to apply the algorithm.
To smooth some elements for 10 iterations:
*createmark(elements,1) 7 8 9 11 12 13 17 54
*marksmoothsolids(1,10)
      The *createmark() commmand is required.
None.
