*modent_addrepresentations
Adds representation information to a modular entity.
*modent_addrepresentations entity_type entity_id representation_key representation_file representation_file_format
HyperMesh Tcl Modify Command
- entity_type
 - The type of modular entity to add the representation information to. Currently only supported for subsystems.
 - entity_id
 - The ID of the modular entity.
 - representation_key
 - The key of the representation to add, which is unique per subsystem.
 - representation_file
 - The full path and file name of the representation.
 - representation_file_format
 - The representation file format. Valid values are Nastra, OptiStruct, Ls-Dyna, Radioss Block, Pamcrash 2G, and Abaqus.
Examples
*modent_addrepresentations subsystems 3 "crash5" "C:/representations/Subsystem1_Crash5mm.k " "Ls-Dyna"Errors
   # Handle error
}Version History
2020
