*panelcreation
Creates a panel entity.
*panelcreation elemMark=<value> name=<value> findPanel=<value>
HyperMesh Tcl Modify Command
- elemMark=<value>
 - The ID of the input elements. Valid values are 1 and 2.
 - name=<value>
 - The name of the panel entity.
 - findPanel=<value>
 - 0 - DIrectly create the panel entity using the input elements
Examples
*createmark elems 1-10
*panelcreation 1 panel1 0*createmark elems 1-10
*panelcreation 1 panel1 1Errors
   # Handle error
}Version History
2020
