*createcirclecenterpoint
Creates a point at the center of a circle defined by 3 input points.
*createcirclecenterpoint point_id1 point_id2 point_id3
HyperMesh Tcl Modify Command
- point_id1
 - The ID of the first point defining the circle.
 - point_id2
 - The ID of the second point defining the circle.
 - point_id3
 - The ID of the third point defining the circle.
Examples
*createcirclecenterpoint 100 200 300Errors
   # Handle error
