*attributeupdatedoublearrayelementmark
Updates one element of an attribute of type double array.
*attributeupdatedoublearrayelementmark entity type mark identifier solver status behavior index value
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - index
 - Index into the array (first index is zero).
 - value
 - The value of the array element.
*createmark(materials,1) 7 8
*attributeupdatedoublearrayelementmark(materials,1,615,2,2,0 ,0,10.5)
