*translatemark
Translates a selection of entities along a vector.
*translatemark entity_type mark_id vector_id distance
HyperMesh Tcl Modify Command
This command translates a selection of entities along a vector.
- entity_type
 - The type of entity to translate.
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - vector_id
 - The ID of the vector to use for the translation. This is defined using the *createvector command.
 - distance
 - The distance to translate.
To translate node 1 5 units along the y-axis:
*createvector 1 0.0 1.0 0.0
*createmark nodes 1 1
*translatemark nodes 1 1 5.0
   # Handle error
