*set_flags_for_2dmesh_context
Preserves selection topology used by 2D meshing.
*set_flags_for_2dmesh_context <pption1>=<value1> ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Preserves selection topology used by 2D meshing. This is useful while doing 2D meshing iteratively on fixed selections, but modifying edge and face settings iteratively.
automatic
0 - Does not delete FE for failed surface selection and continues to retain previous topology
1 - Does not populate topology information, but ensures that when meshing fails, existing FE is deleted for given surface selection to ease identifying failed surfaces
interactive
0 - Clear the last preserved topology information.
1 - The next meshing command will populate topology information and preserve it for subsequent meshing calls. This allows changing meshing parameters on edges and faces. This also ensures that when meshing fails, existing FE is deleted for a given surface selection to ease identifying failed surfaces.
Examples
To set interactive meshing option to 1:
*set_flags_for_2dmesh_context interactive=1
   # Handle error
Version History
2020.1
