*springsupdate
Updates the properties of spring elements.
*springsupdate mark dofflag dof propertyflag property vectorflag vectorid
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark which contains the spring elements to be updated.
 - dofflag
 - Set to 1 if the dofs should be updated, otherwise 0.
 - dof
 - The degree of freedom which the spring elements should be updated to (one digit of 1-6).
 - propertyflag
 - Set to 1 if the property should be updated, otherwise 0.
 - property
 - The property to which the element should point.
 - Vectorflag
 - Set to 1 if the vector should be updated, otherwise 0.
 - vectorid
 - The ID of the orientation vector associated with the spring element.
To update spring element 16, 17, and 18 to have a degree of freedom of 3 and a property reference to sprate, without an orientation vector:
*createmark(elements,1) 16 17 18
*springsupdate(1,1,3,1,"sprate",0)
None.
