*wadlines_createspheres
Creates sphere surfaces for testing rear reference line of pedestrian impact.
*wadlines_createspheres double_array number_of_doubles radius
HyperMesh Tcl Modify Command
double_array
The double array ID that contains the 3D coordinates of the center of each sphere. The double array is created using the *createdoublearray command. This should always be set to 1.
number_of_doubles
Integer indicating the size (number of doubles) in the double array created using *createdoublearray. This should be 3 times the number of spheres.
radius
The radius of each sphere.
Examples
To create 2 spheres with radius 82.5:
*createdoublearray 6 1431.92088 -727.229931 1025.94747 1430.19016 -722.93938 1025.89459
*wadlines_createspheres 1 6 82.5
   # Handle error
Version History
2021
