*isolateonlyentity
Turns on the display of an entity and turns off the display of all others across types.
*isolateonlyentity entity_type search_type id_name string_array number_of_strings
HyperMesh Tcl Modify Command
- entity_type
 - The type of entity to display.
 - search_type
 - The method used to specify the entity. The entity is specified using the id_name argument. Valid values are:
 - id_name
 - The ID or name of the entity, depending on search_type.
 - string_array
 - The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using
            *createstringarray. The valid strings are:
- elements_off
 - This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
 - geometry_off
 - This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
 - showcomps
 - This indicates that components in which elements/geometry are referred will also be shown when you show elements/geometry. If not provided, only specified elements/geometry are shown.
Examples
To isolate only geometry and elements for component with ID 3:
*isolateonlyentity comps "by id" 3
      To isolate only elements for component with ID 3:
*createstringarray 2 geometry_off
*isolateonlyentity comps "by id" 3 1 2
   # Handle error
}Version History
11.0.130
