*setelemqualityparamactive
Sets the on/off state for a specified element quality parameter.
*setelemqualityparamactive param_id activ
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the on/off state for a specified element quality parameter.
param_id
Specifies the element quality check parameter ID to update. Valid values are:
  • 0 - min size
  • 1 - max size
  • 2 - aspect ratio
  • 3 - warpage
  • 4 - max interior angle quad
  • 5 - min interior angle quad
  • 6 - max interior angle tria
  • 7 - min interior angle tria
  • 8 - skew
  • 9 - Jacobian
  • 10 - chordal deviation
active
  • 0 - Inactive/off
  • 1 - Active/on
Examples
To activate "warpage" parameter:
*setelemqualityparamactive 3 1
To disable "Jacobian" parameter:
*setelemqualityparamactive 9 0
   # Handle error
Version History
12.0.110
