*exportshapes
Exports shape design variables and shapes in several formats.
*exportshapes analysiscode subcode outputfile
HyperMesh Tcl Modify Command
- analysiscode
 - The analysis code for which the output is needed.
- OptiStruct
 - Nastran
 - Genesis
 - HyperStudy
 - Templex
 - HyperOpt
 - subcode
 - This indicates the specific format/item to be output.
- Valid subcodes for each analysis code
 - OptiStruct, Nastran, Genesis None, long, force, moment, temperature
 - outputfile
 - The output file name.
*exportshapes("OptiStruct","long","shape.dat")
