*collisioncheck_temp
Performs a collision detection.
*collisioncheck_temp mark_id_int_elems mark_id_pene_elems mark_id_int_surfs mark_id_pene_surfs mark_id_pene_nodes self_check reserved1 ?pair_angle? ?store_segments? ?mark_adjoining? ?topo_feature_angle? ?pair_results?
HyperMesh Tcl Modify Command
Performs a collision detection using the input entities defined by hm_collisionentitycreate. This must be preceded by hm_collisioninit and one or two calls to hm_collisionentitycreate. Multiple calls to this API can be made to perform different detections.
This command is a temporary command and may be deprecated in a future release.
The inputs are the same as hm_collisioncheck except for:
pair_results
If set to 0, detailed pair results are not calculated and none of the hm_collisionget* APIs can be used (default, same as hm_collisioncheck).
If set to 1, detailed pair results are calculated and the hm_collisionget* and hm_collisionwriteresultsfile APIs can be used (same as hm_collisioncheck).
If set to 2, additional collision result entities are created that can be rendered in the collision browser or used as input of other commands like *collisionfix_temp (option not available in hm_collisioncheck).
If set to 3, only the collision result entities are created (for browser , *collisionfix_temp...), but not the detailed pair results (for hm_collisionget*). This option is not available for hm_collisioncheck, and is only available for the collirad engine.
Note that hm_collisionend does not delete any collision result entities. The deletion must be handled using *deletemark.
To check intersections and penetrations of comps 1001 and 1002, using the nodes of comp 1002 against the elements of comp 1001 for the penetration check, creating only collision result entities:
*createmark comps 1 1001
*createmark comps 2 1002
hm_collisioninit [hm_collisiongetconfig collirad]
hm_collisionentitycreate comps 1 0 1 0.0 0 0 0 0 1
hm_collisionentitycreate comps 2 0 1 0.0 0 0 0 0 2
*collisioncheck_temp 1 1 0 0 1 0 0 90.0 0 0 0.0 3
hm_collisionend
   # Handle error
Version History
2017.1
