*createelementsbetweenpoints
Creates a spotweld element between two surfaces at the marked points with an element type, coordinate system, and property ID.
*createelementsbetweenpoints surf1_markmask surf2_markmask markmask tol createplot configval syst code *property
HyperMesh Tcl Modify Command
- surf1_markmask
 - First or multiple surfaces in the mark.
 - surf2_markmask
 - Second surface in the mark, if given.
 - markmask
 - Marked points.
 - tol
 - Search tolerance to identify surfaces.
 - createplot
 - Creates a plot.
 - configval
 - Element type configuration value.
 - syst
 - Local coordinate system switch.
- 0 - Without coordinate system.
 - 1 - With coordinate system.
 - code
 - Code for one or all surface options.
- 0 - All surfaces.
 - 1 - One surface.
 - *property
 - Name of property collector. Retrieves property ID.
Examples
*createelementsbetweenpoints(1,2,2,0.01,1,21,1,1, "name_prop")
