*hf_FeatureFromSurfaces
Creates the feature line from surfaces.
*hf_FeatureFromSurfaces entity_type mark_id
HyperMesh Tcl Modify Command
This command creates the feature line from selected surfaces. It stitches together all the surfaces to extract a single free edge.
entity_type
Must be set to surfs.
mark_id
The mark ID containing the surfaces. Valid values are 1 and 2.
To create the feature from surface 644:
*createmark surfaces 1 644
*hf_FeatureFromSurfaces surfaces 1
   # Handle error
Version History
10.0
