*CE_ConvertByMark
Converts between bolt and spot connectors.
*CE_ConvertByMark mark_id source_style target_style reserved1 reserved2
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the connectors to convert. Valid values are 1 and 2.
source_style
The source connector style.
spot
bolt
target_style
The target connector style.
spot
bolt
reserved1
Reserved for future use. Must be set to 0.
reserved2
Examples
To convert spot connectors 101 and 102 to bolt connectors:
*createmark connectors 1 101 102
*CE_ConvertByMark 1 "spot" "bolt" 0 0
   # Handle error
Version History
13.0.110
