*stackreverse
Reverses the stack direction of selected entities.
*stackreverse entity_type mark_id size
HyperMesh Tcl Modify Command
Reverses the stack direction of selected entities. Currently only supported for Abaqus continuum shell elements.
entity_type
The type of entity to reverse. Valid values are elements and components.
mark_id
The ID of the mark containing the entities to reverse. Valid values are 1 and 2.
size
The size in model units of the stack display.
To reverse the stack direction of elements 1-10 using a size of 10.0:
*createmark elems 1 1-10
*stackreverse elems 1 10.0
   # Handle error
Version History
11.0.120
