*gapelement
Creates a gap element.
*gapelement node1 node2 property name vectorid
HyperMesh Tcl Modify Command
- node1
 - The ID of the first node of the gap element.
 - node2
 - The ID of the second node of the gap element.
 - property name
 - The property name which should be assigned to the gap element.
 - vectorid
 - The orientation vector ID associated with the gap element.
*gapelement(5,245,gapprop,0)
