*xelem_bynodelist
Creates a new element(/XELEM) of config 27 and type 1 using a node list.
*xelem_bynodelist node_list_id node_distance
HyperMesh Tcl Modify Command
Creates a new element(/XELEM) of config 27 and type 1 using a node list.. This is currently only supported for Radioss.
node_list_id
The ID of the ordered node list to use to create the element. There must be at least 2 nodes in the list. Valid values are 1 and 2.
node_distance
The distance at which intermediate nodes are to be created. This also creates a node set from the new nodes.
Examples
Create a xelem element with nodes 1, 10, 20 and node distance as 2:
*createlist nodes 1 1 10 20
*xelem_bynodelist 1 2
   # Handle error
Version History
2019
