*adjustnodes
Fixes the penetrations by moving only the failed nodes.
*adjustnodes mark reduction scale segment magnitude_mode
HyperMesh Tcl Modify Command
- mark
 - The mark of the entity to be modified.
 - reduction
 - The average thickness reduction.
 - scale
 - The thickness scale factor.
 - segment
 - The segment orientation option.
 - magnitude_mode
 - Determines if a magnitude percentage or a uniform size is to be used.
- 1 - Magnitude percentage.
 - 0 - Uniform size.
Examples
To move the failed nodes. *createmark() and *templatefileset() are required.
*createmark(groups, 1) "E2E"
*adjustnodes(1,0,1,1,1)
