*topography_reanalysis
Extract the final geometry from OptiStruct topology, topography and shape optimization results and inherit the boundary conditions for reanalysis.
*topography_reanalysis grid_filename sh_filename autobead bead_threshold layers isosurface mode density_threshold
HyperMesh Tcl Modify Command
- grid_filename
 - The full name and path to the OptiStruct .grid results file generated from the optimization.
 - sh_filename
 - The full name and path to the OptiStruct .sh results file generated from the optimization.
 - autobead
 - Flag that determines whether to create beads. Valid values are:
 - bead_threshold
 - The threshold value for bead creation (0 ≤ bead threshold ≤1).
 - isosurface
 - Flag that determines whether to create isosurfaces. Valid values are:
 - mode
 - Iso-surface mode indicating how to process non-design elements. Valid values are:
 - density_threshold
 - Threshold value for topology optimization (0 ≤ density threshold ≤ 1).
*topography_reanalysis "C:/test/os1.grid" "C:/test/os1.sh" 1 0.3 1 1 3 0.3Errors
   # Handle error
}Version History
11.0
