*system
Creates and updates coordinate systems.
*system entity_type ?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?
HyperMesh Tcl Modify Command
<option>=<value> options can be provided in any order.
- entity_type
 - The type of input entity. Must be set to nodes.
 - axisname=<value>
 - The name of the axis to define. This is required. Valid values are:
 - axisnode=<value>
 - The axis node ID. This is required if coordinate values axisx, axisy and axisz are not given.
 - axisx=<value>
 - The axis x coordinate value. This is required if axisnode is not given.
 - axisy=<value>
 - The axis y coordinate value. This is required if axisnode is not given.
 - axisz=<value>
 - The axis z coordinate value. This is required if axisnode is not given.
 - NodeMark=<value>
 - The ID of the mark containing origin nodes at which to create systems. This is required if originx, originy and originz or originnode are not given.
 - planename=<value>
 - The name of the plane to define. This is required. Valid values are:
 - originnode=<value>
 - The origin node ID. This is required if originx, originy and originz or NodeMark are not given.
 - originx=<value>
 - The origin x coordinate value. This is required if originnode and NodeMark are not given.
 - originy=<value>
 - The origin y coordinate value. This is required if originnode and NodeMark are not given.
 - originz=<value>
 - The origin z coordinate value. This is required if originnode and NodeMark are not given.
 - planenode=<value>
 - The plane node ID. This is required if planex, planey and planez are not given.
 - planex=<value>
 - The plane x direction coordinate value. This is required if planenode is not given.
 - planey=<value>
 - The plane y direction coordinate value. This is required if planenode is not given.
 - planez=<value>
 - The plane z direction coordinate value. This is required if planenode is not given.
 - system=<value>
 - The system ID to be edited.
 - type=<value>
 - The type of system to create. This is required. Valid values are:
Examples
To create a new rectangular system:
*system nodes type=0 originx=0.01 originy=0.2 originz=0.3 axisname=z-axis axisx=0.3 axisy=0.4  axisz=0.2  planename=xz-plane  planex=0.4  planey=0.6 planez=0.7
      To update a system:
*system nodes type=RECTANGULAR originx=0.01 originy=0.2 originz=0.3
   # Handle error
}Version History
2019
