*solid_untrim
Untrims solids by removing surfaces that separate them.
*solid_untrim mark_id force
HyperMesh Tcl Modify Command
This command creates a full or partial cone or cylindrical solid.
mark_id
The ID of the mark containing the surfaces to untrim. Valid values are 1 and 2.
force
0 - Only surfaces that separate solids (solid on both sides) are removed.
1 - Surfaces are deleted even if there is no solid on one of the sides. Normally this causes solid destruction but it may be useful as a way to remove solid cavities.
To untrim surface 100:
*createmark surfs 1 100
*solid_untrim 1 0
   # Handle error
