*loadtype
Sets the load types to the current global value.
*loadtype config type
HyperMesh Tcl Modify Command
- config
 - The load configuration that is to have its type changed.
 - type
 - The type which the configuration should become.
To set the type of forces to 2:
*loadtype(1,2)
      After the type has been set, all loads of the corresponding configuration are set to the value of type.
None.
