*scalemark
Scales a selection of entities by multiplying the coordinates.
*scalemark entity_type mark_id scale_x scale_y scale_z origin
HyperMesh Tcl Modify Command
This command scales a selection of entities by multiplying the coordinates.
- entity_type
 - The type of entity to translate.
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - scale_x
 - The multiplication factor for the x-coordinate.
 - scale_y
 - The multiplication factor for the y-coordinate.
 - scale_z
 - The multiplication factor for the z-coordinate.
 - origin
 - The node ID defining the origin of the scaling. If set to 0, the global origin is used.
To scale component top uniformly 10 times about node 3:
*createmark comps 1 top
*scalemark comps 1 10.0 10.0 10.0 3
   # Handle error
