*morphtranslateshapemark
Translates shapes to specified node positions and applies them only to the nodes on the mark.
*morphtranslateshapemark s_entity_type s_mark_id n_entity_type n_mark_id a_entity_type a_mark_id base_node_id mode tol con
HyperMesh Tcl Modify Command
This command will translate each shape on the mark by a vector measured from the basenode to each node on n_mark_id and affect only the nodes on a_mark_id. The shapes may be applied to the mesh, created as new shapes, added to existing shapes, or may replace existing shapes.
s_entity_type
Must be set to shapes.
s_mark_id
The mark ID of the shapes. Valid values are 1 and 2.
n_entity_type
Must be set to nodes.
n_mark_id
The mark ID for the translate final position nodes. Valid values are 1 and 2.
a_entity_type
a_mark_id
The mark ID for target nodes. Valid values are 1 and 2.
base_node_id
ID of the base node for translate initial positions.
mode
0 - Apply each shape to the mesh
1 - Apply each shape and add the perturbations to the original shape
2 - Apply each shape and overwrite the original shape
3 - Apply each shape and create a new shape or shapes
4 - Create a new shape or shapes but do not apply them to the mesh
tol
The "envelope" or distance around the translated shape inside which nodes are affected.
con
0 - Do not use constraints
1 - Use constraints
Examples
To translate a shape from one node to another and apply it to the mesh:
*createmark shapes 1 1
*createmark nodes 1 12
*createmark nodes 2 "all"
*morphtranslateshapemark shapes 1 nodes 1 nodes 2 11 0 3.0 1
To translate all shapes from one node to another and create new shapes, but only on selected nodes:
*createmark shapes 1 "all"
*createmark nodes 2 1 2 3 4 5 6 7 8 9 10 11 12
*morphtranslateshapemark shapes 1 nodes 1 nodes 2 11 4 3.0 1
Incorrect usage of *morphtranslateshapemark results in a Tcl error. To detect errors, you can use the catch command:
if { [ catch {*morphtranslateshapemark shapes 1 nodes 1 nodes 2 11 0 3.0 1} ] } {
# Handle error
Version History
10.0
