*encryptentity
Encrypts an entity.
*encryptentity entity_type id key
HyperMesh Tcl Modify Command
Encrypts an entity. Currently only supported for Radioss.
entity_type
The type of entity to encrypt. Valid values are curves, mats and props.
id
The ID of the entity to encrypt.
key
For Radioss, this is the value to use for /KEY. Valid values are 01-99.
To encrypt material 100 using key 55:
*encryptentity mats 100 55
   # Handle error
Version History
14.0.120
