*blmesh_2d_input_bl
Specifies boundary layer input.
*blmesh_2d_input_bl fixed_entity_type fixed_mark_id float_entity_type float_mark_id
HyperMesh Tcl Modify Command
Specifies boundary layer input for *bl_mesh2d2 and *bl_mesh2d_computeblthickness1. If *blmesh_2d_input_bl is not called before either command, then all edges of the selected region are considered as boundary layer edges.
fixed_entity_type
The type of entities to use for the fixed boundary layer. Valid values depend on the base_entity_type value specified in *bl_mesh2d2.
If base_entity_type is surfs, then the only valid value is lines.
If base_entity_type is elems, then the valid values are elems or nodes. For elems, only plotel elements are allowed.
fixed_mark_id
The ID of the mark containing the fixed entities. Valid values are 1 and 2.
float_entity_type
The type of entities to use for the float boundary layer. Valid values depend on the base_entity_type value specified in *bl_mesh2d2.
float_mark_id
The ID of the mark containing the float entities. Valid values are 1 and 2.
Examples
To create a 5 layer boundary mesh with a quad dominated mesh of size 2.0 on surface 10, with the first layer being 0.15 thick and a growth rate of 1.2, using boundary layer elements 10 and 11 as fixed and 12 and 13 as float, and non-boundary layer elements 1 and 2 as fixed and 5 and 6 as float:
*createmark elems 1 10 11
*createmark elems 2 12 13
*blmesh_2d_input_bl elems 1 elems 2
*createmark elems 1 1 2
*createmark elems 2 5 6
*blmesh_2d_input_nonbl elems 1 elems 2 1
*createstringarray 2 "element_size: 2.0" "element_type: quads"
*createmark surfs 1 10
*blmesh_2d2 surfs 1 5 0.15 1.2 1 2 2
To create a 5 layer boundary mesh from elements 10-100, with the first layer being 0.15 thick and a growth rate of 1.2, a core-to-BL ratio of 2.5, a corner factor of 1.0, using boundary layer elements 10 and 11 as fixed and 12 and 13 as float, and non-boundary layer elements 1 and 2 as fixed and 5 and 6 as float:
*createmark elems 1 10-100
*blmesh_2d_computeblthickness elems 1 5 0.15 1.2 2.5 1.1
   # Handle error
