*findedges1
Finds element free or T-connected edges.
*findedges1 entity_type mark_id edge_type created_entity smooth break_angle
HyperMesh Tcl Modify Command
This command finds and displays element free or T-connected edges as either free lines or plot elements in a new component named ^edges.
- entity_type
 - The entity types to find edges for. Valid values are comps and elems.
 - mark_id
 - The mark ID containing the entities. Valid values are 1 and 2.
 - edge_type
 - The type of edges to find:
- 0 - Free edges.
 - 1 - T-connected edge
 - created_entity
 - The entity type to create on the found edges:
- 0 - Plot elements
 - 1 - Free lines
 - smooth
 - The smoothing to use when created_entity is 1:
- 0 - No smoothing.
 - 1 - Smooth the lines through the nodes.
 - break_angle
 - The angle specifying when to break the feature line created into multiple line segments when created_entity is 1. When the angle between adjoining elements along the feature is larger than the specified value, it splits the line into multiple segments.
*createmark comps 1 fender
*findedges1 comps 1 0 1 0 0Version History
13.0
