*assemblyremovemark
Removes the components within a mark from the components contained in an assembly mark.
*assemblyremovemark assemblymark entitytype entitymark
HyperMesh Tcl Modify Command
- assemblymark
 - The ID of the assembly mark from which you wish to remove assemblies, components, or multibodies.
 - entitytype
 - The type of entity contained on the entitymark: assemblies, components, or multibodies.
 - entitymark
 - The ID of the mark to be removed from the assembly.
Examples
To remove component 14 from assembly 2:
*createmark(assemblies,2) 2
*createmark(components, 1) 14
*assemblyremovemark(2,components,1)
