*pressureonelement_curve
Creates a pressure load on an element.
*pressureonelement_curve id face_index x_comp y_comp z_comp magnitude curve_id x_scale
HyperMesh Tcl Modify Command
- id
 - The ID of an element on which to apply the pressure.
 - face_index
 - The face index of the solid element. Ignored, if the element is a shell element.
 - x_comp
 - The x-component of pressure.
 - y_comp
 - The y-component of pressure.
 - z_comp
 - The z-component of pressure.
 - magnitude
 - The magnitude of the pressure.
 - curve_id
 - The ID of a curve defining the magnitude of the load vs time.
 - x_scale
 - A scale factor applied to the x-axis (or time axis) of the curve.
*pressuresonelement_curve 10 2 0 0 0 4.0 9 1.0Errors
   # Handle error
}Version History
14.0
