*CE_AddLinkEntitiesDirectByRule
Allows the user to add link directly to the connectors without considering tolerance or number of layers.
*CE_AddLinkEntitiesDirectByRule mark_id link_type link_rule link_state link_string_array link_number_of_strings extra_link_string_array extra_link_number_of_strings create_group
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of connectors to update. Valid values are 1 and 2.
link_type
The entity type to be added to the connectors as links.
link_rule
The rule by which the link entity is added to the connector. If the rule is specified, the modification is performed in accordance with the rule. For example, a value of 2 requires link IDs to be specified for link_string_array. Valid values are:
0 - Undefined
1 - None
2 - Use ID
3 - Use Name
4 - Proximity
5 - Use UID
link_state
The state of the link entity which is to be added:
0 - Undefined
1 - Elems
2 - Geom
link_string_array
A string array containing the list of link IDs/names/UIDs to be added directly to connectors, created using*createstringarray. This must be set to 1.
The strings are generally IDs/names/UIDs based on the link_rule.
Integer indicating the size (number of strings) in the link_string_array created using *createstringarray.
A string array containing the list of extra link additions allowed for spots and seams, created using*createstringarray. This must be set to 1.
Integer indicating the size (number of strings) in the extra_link_string_array created using *createstringarray.
create_group
0 - Add the newly chosen links separately to the connector
1 - Add the newly chosen links as a group to the connector
Examples
Add two component links (ID 1 and 2) directly to connector ID 2 of type spot using without creating a group link:
*createmark connector 1 2
*createstringarray 2 1 2
*createarray 2 2 2
*CE_AddLinkEntitiesDirectByRule 1 comps 2 1 1 2 1 2 0
   # Handle error
Version History
2019
