*modelcheck_runchecks
Runs model checker checks.
*modelcheck_runchecks ?check_display_name? ?entity_type? ?error_type? ?mark_id?
HyperMesh Tcl Modify Command
If executed with no arguments, then all checks for all entity types in the profile are run.
check_display_name
The GUI display name of the check. This is case sensitive.
If not provided or set to "ALL", then all the checks of the entity_type for the profile are run.
entity_type
The type of entity to be checked.
If not provided or set to "ALL", then all checks of all entity types are run.
error_type
The type of errors to check, ERROR, WARNING, INFO or ALL.
If not provided or set to "ALL", then all checks of all error types are run.
mark_id
The ID of the mark of entities for which model checker is to be run. Valid values are 1 and 2.
Examples
Run the check named "checkname":
*modelcheck_runchecks checkname
Run all checks on properties 1-10 :
*createmark props 1 1-10
*modelcheck_runchecks "" props "" 1
   # Handle error
Version History
2019
