*verticesmarksuppress
Removes the selected fixed points from their surfaces, and gives the option to create free points at those locations.
*verticesmarksuppress mark_id break_angle save_as_points
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the points. Valid values are 1 and 2.
break_angle
The test threshold used to prevent the accidental removal of points that correspond to corners,which are necessary for proper mesh generation.
save_as_points
1 - To create free points at the locations of the removed fixed points.
0 - Do not create free points.
To suppress points 25 and 26, using a 30 degree breakangle:
*createmark points 1 25 26
*verticesmarksuppress 1 30.0 0
None.
