*segmentsetreversenormals
Reverse normals of a segment set.
*segmentsetreversenormals name mark_id reverse_flag
HyperMesh Tcl Modify Command
- name
 - The name of the segment set to update.
 - mark_id
 - The ID of the mark containing the elements to reverse when reverse_flag is 1. Valid values are 1 and 2.
 - reverse_flag
 - 0 - Reverse all, mark_id is ignored
Examples
*createmark elements 1 100-150
*segmentsetreversenormals "test" 1 1Errors
   # Handle error
}Version History
2020
