*linefromsurfedgecomp
Creates lines by copying one or more surface edges.
*linefromsurfedgecomp entity_type mark_id comp_flag
HyperMesh Tcl Modify Command
This command takes selected surface edges or edges of selected surfaces and makes their copy as free lines. This command replaces the command *linefromsurfedge which only creates a copy of edges in the component of the surfaces.
entity_type
Type of selected entity, can be SURFS or LINES.
If surfaces are selected, then a copy of all surface edges is created.
mark_id
The ID of the mark containing the selected entities. Valid values are 1 and 2.
comp_flag
Flag to specify whether copied lines are created in current component (1) or in the component of surfaces they were copied from (0).
To copy all surface edges of surface with ID 12 into the current component:
*createmark surfs 1 12
*linefromsurfedgecomp surfs 1 1
This command does not return any errors that can be handled.
