*modent_registerconstraintruleoptions
Registers a list of options that control the behavior of add/move/remove operations for a modular entity.
*modent_registerconstraintruleoptions modular_entity_type modular_entity_action independent_entity_type dependent_entity_type add_behavior_for_dependent_entity_type add_behavior_for_shared_dependent_entity_type
HyperMesh Tcl Modify Command
Registers a list of options that control the behavior of add/move/remove operations for a modular entity. Valid entity combinations are:
Table 1.
Independent Entity Types Dependent Entity Types
beamsectcols beamsects
components elements
components materials
components nodes
components properties
loadcols loads
materials curves
properties materials
systcols systems
vectorcols vectors
modular_entity_type
The type of modular entity. Currently only supported for subsystems.
The type of modular entity action:
1 - Reset to defaults
2 - Add/move/remove
The type of independent entities to add/move/remove to/from modular entities.
The type of dependent entities to add/move/remove to/from modular entities.
0 - Do not add/move/remove to modular entities
1 - Add/move/remove to modular entities
0 - Do not add/move/remove independent entities to modular entities if they have any dependent entities shared with other modular entities
0 - Do not add/move/remove dependent entities to modular entities if they are shared with other modular entities
1 - Add/move/remove dependent to modular entities if they are shared with other modular entities
Examples
When adding/moving/removing components to subsystems, add/move/remove properties and shared properties:
*modent_registerconstraintruleoptions subsystems 2 components properties 1 2
When adding/moving/removing components to subsystems, add/move/remove nodes, but prevent the action if there are any nodes shared with other subsystems:
*modent_registerconstraintruleoptions subsystems 2 components nodes 1 0
   # Handle error
Version History
2020
