*morphcreateline
Creates a line for a given node list.
*morphcreateline list_id
HyperMesh Tcl Modify Command
This command is used to create a line from a list of nodes for use with several morphing operations.
node_list
The ID of the list containing the nodes. Valid values are 1 and 2.
To create a line using nodes 534, 538 and 542:
*createlist nodes 2 534 538 542
*morphcreateline 2
   # Handle error
Version History
14.0.110
