*voxel_lattice_hex_mesh_create
Creates voxel elements from the inputs given to the voxel session.
HyperMesh Tcl Modify Command
Creates voxel elements from the inputs given to the voxel session. This command can be called any number of times after modifying the input options.
This must be preceeded by a call to *voxel_lattice_hex_mesh_init and either a call to *voxel_lattice_hex_mesh_import or one of the *voxel_lattice_hex_mesh_add... commands.
To create voxels of size 10 for include components 100-110 and exclude components 200-203:
*voxel_lattice_hex_mesh_init 10
*voxel_lattice_hex_mesh_fill_voids 0
*createmark comps 1 100-110
*voxel_lattice_hex_mesh_add_entities comps 1 1
*createmark comps 2 200-203
*voxel_lattice_hex_mesh_remove_entities comps 2 1
*voxel_lattice_hex_mesh end
   # Handle error
Version History
2019.1
