*show_new_target
Draws a segment in the new target component. This segment connects the point to offset with the target point.
*show_new_target face offsetpoint_x offsetpoint_y offsetpoint_z target_x target_y target_z code
HyperMesh Tcl Modify Command
face
Index of the surface to be offset.
offsetpoint_x
X coordinate of the point to be offset.
offsetpoint_y
Y coordinate of the point to be offset.
offsetpoint_z
Z coordinate of the point to be offset.
target_x
X coordinate of the pilot point.
target_y
Y coordinate of the pilot point.
target_z
Z coordinate of the pilot point.
code
  • 0 The target point is a midpoint between the offset point and the pilot point.
  • 1 The target point is the pilot point.
  • 2 The target point is a midpoint between the offset point and the pilot point. If the offset point is at a vertex of the surface to offset, the target is combined with any existing targets for that vertex and displays the combined target in the new target component.
  • 3 The target point is the pilot point. If the offset point is at a vertex of the surface to offset, the target is combined with any existing targets for that vertex and displays the combined target in the new target component.
  • 4 Behaves exactly as option 2, but also displays the targets being combined and the target planes in the targets being combined component.
  • 5 Behaves exactly as option 3, but also displays the targets being combined and the target planes in the targets being combined component.
  • -1 The command combines the targets that existed at the vertex; the pilot point is ignored.
  • -5 As for option -1, but also displays the targets being combined component.
Users cannot manually employ this command, because HyperMesh must internally generate the index values (they cannot simply be typed in).
None.
