*exportbom
Exports a UDMXML BOM file for a given part.
*exportbom file_name "?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?"
HyperMesh Tcl Modify Command
<option>=<value> options must be enclosed in quotes, but can be provided in any order.
- file_name
 - The name and path of the file to write.
 - part_hmid=<value>
 - The HyperMesh part ID to be used as root for exporting.
 - part_udmid=<value>
 - If part_hmid is not provided, this is the UDMID of the HyperMesh part to be used as root for exporting.
 - recursive=<value>
 - 0 - Only the top level elements under the part ID are exported.
 - subsystem=<value>
 - 0 - Do not export subsystem structure.
*exportbom c:/temp/exportedbom.xml "part_hmid=2"Errors
   # Handle error
}Version History
2019.1
2020 - Added new option subsystem.
